I have a 2013 GMC Sierra with a 5.3L V8 I have a P219A code I know it can be the O2 sensors, the fuel injector, or a vac leak but i'm not a rich person so I can't just buy all the parts just because so i'm hoping someone can help me pin down the most likely part to go for.
Problems:
     MIL P219A
     Little hiccups here and there
     Lost of fuel MPG use to average ~ 17-19 MPG now ~ 10-13 MPG HWY
Fixes so far:
     Ran fuel system cleaner
     Cleaned MAF sensor
     New filters
     Tried different fuel types
OBD2 Freeze Frame Data:
Parameter Description Results
DTC that caused required freeze frame data storage P219A
Fuel Sys 1 CL
Fuel Sys 2 CL
Calc Load 66.3 %
ECT 190 °F
STFT B1 -2.3 %
LTFT B1 -0.8 %
STFT B2 4.7 %
LTFT B2 -1.6 %
Fuel Pres 44 psi
MAP 22 inHg
Eng RPM 2037
Veh Speed 80 mph
Spark Adv 37.0 °
IAT 48 °F
MAF 6.23 lb/min
TPS 39.2 %
O2S B1 S1 0.69 V
STFT B1 S1 -2.3 %
O2S B1 S2 0.66 V
STFT B1 S2 99.2 %
O2S B2 S1 0.08 V
STFT B2 S1 4.7 %
O2S B2 S2 0.66 V
STFT B2 S2 99.2 %
Run Time 290 sec
Command EVAP 100.0 %
Fuel Level 78.0 %
Warm-up DTC Clr 1
Clr Dist 11 miles
EVAP_VP -3.6 InH2O
BARO 25 inHg
CAT Te 11 1562 °F
CAT Te 21 1562 °F
ECU Volts 14.32 V
LOAD Value 43.9 %
EQ Ratio 1.00
Rel TPS 25.1 %
Ambient 45 °F
TPS B 38.8 %
ACC Pedal D 19.2 %
ACC Pedal E 9.4 %
Command TAC 35.7 %
FUEL_TYP NONE
ALCH_PCT 11.0 %
Any help would be great.
The free test would be pretty simple. Swap the upstream o2 sensors side to side.
If the code changes to a P219B, then that sensor is likely at fault. Or if it gives a code for bank 2 after the o2 sensor swap.
Not on vehicles with a fuel pump control module. All flex fuel trucks of that era have fuel pump control modules that vary the fuel pressure. Under low load situations the fuel pressure will be in the 40's and only jump to around 58-60 under heavy throttle.
The data shows o2 sensor O2S B1 S2 totally different measurement from the other 2, could that sensor be the problem?
Sorry for the late response but I tried to swap the upstream O2 sensors and the and the problem is still there but did seem to take 2 days before I got the check engine light that's why I haven't responded yet still have p219a
Problems:
     MIL P219A
Fixes so far:
     Cleaned MAF sensor
     New filters
Fuel Sys 1 CL
Fuel Sys 2 CL
Calc Load 66.3 %
ECT 190 °F
STFT B1 -2.3 %
LTFT B1 -0.8 %
STFT B2 4.7 %
LTFT B2 -1.6 %
Fuel Pres 44 psi
MAP 22 inHg
Eng RPM 2037
Veh Speed 80 mph
Spark Adv 37.0 °
IAT 48 °F
MAF 6.23 lb/min
TPS 39.2 %
O2S B1 S1 0.69 V
STFT B1 S1 -2.3 %
O2S B1 S2 0.66 V
STFT B1 S2 99.2 %
O2S B2 S1 0.08 V
STFT B2 S1 4.7 %
O2S B2 S2 0.66 V
STFT B2 S2 99.2 %
Run Time 290 sec
Fuel Level 78.0 %
Warm-up DTC Clr 1
Clr Dist 11 miles
EVAP_VP -3.6 InH2O
BARO 25 inHg
CAT Te 11 1562 °F
CAT Te 21 1562 °F
ECU Volts 14.32 V
LOAD Value 43.9 %
EQ Ratio 1.00
Rel TPS 25.1 %
Ambient 45 °F
TPS B 38.8 %
ACC Pedal D 19.2 %
ACC Pedal E 9.4 %
Command TAC 35.7 %
FUEL_TYP NONE
ALCH_PCT 11.0 %
Have you changed any of the oxygen sensors?  Aftermarket sensors do not play nice with the computer system.  Use GM OE only, not even Denso unless it came in the ACDelco/GM box.
MAP sensor readings at idle ought to be between 19-42 kpa.  What are your LTFTs at idle once warmed up?
Have you inspected the spark plugs?  Does the crankcase oil smell like fuel?  Have you triple checked for vacuum leaks on  and around the intake manifold and brake booster?
  • 6 months later...
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
