My 2014 1500 is throwing a code for the fuel regulator and I’m not sure where it is. I’ve changed out the high pressure sensor but no luck. Any advise.
It’s P0091.
I just dug around some more and noticed it may be either the high pressure fuel pump or a bad connection to the harness. If anyone has more knowledge on the topic it would be appreciated.
28 minutes ago, RyanD77968 said:
It’s P0091.
DTC P0091
Fuel Pressure Regulator Control Circuit Low Voltage
Description
Fuel Pressure Regulator — G18 High Pressure Fuel Pump
The fuel pressure regulator is a solenoid valve that restricts the flow of fuel to the high pressure fuel pump and thereby controls the pressure the pump can produce.  The fuel pressure regulator is a part of the high pressure fuel pump. The fuel pressure regulator is the solenoid valve that controls the pressure in the fuel rail.
Diag chart has you test the wiring to the high pressure pump and its control from the ECM.  If all the wiring is good, needs a high pressure fuel pump.
Testing of the pump below:
Note: The component's temperature should be 19 to 21°C (66 to 70°F) while testing.
  1. Ignition/Vehicle & All vehicle systems » Off
  2. Disconnect the electrical connector: G18 High Pressure Fuel Pump
  3. Test for 0.58 to 0.7 Ω between the test points: Control terminal 1 & Control terminal 2
    • If not between 0.58 and 0.7 Ω
      Replace the component: G18 High Pressure Fuel Pump
    • If between 0.58 and 0.7 Ω
  4. Test for infinite resistance between the test points: Each terminal of the component & The component's housing
    • If less than infinite resistance
    • If infinite resistance
  5. All OK.
Edited by newdude
  • 2 years later...
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
