If you have an integrated (into the seat) seat belt here's how (at least on my 06 Avalanche) to get to it:
You got to remove the arm rest to get the seat cover off. If you ever took a window crank handle off a GM you know there is a little horse (sorta) shoe shaped clip behind the window crank handle, there is a tool for this or you can use a hook fashioned outta coat hanger wire (if you can find a wire coat hanger) and get it off that way; it's prolly going to be a fight in any case. After you get the arm off you may have to remove the seat cover; peel it off by turning it inside out as you go; it's installed the same way it came off, you peel it back on. There is a service manual for this stuff but the dealer is prolly the only people who have a copy, you can prolly get from GM Helm pubs; the same place you get the GM manuals. You may find something at all data or the like.
