Somewhere I found a topic regarding adding a 2m/440cm antenna with a Larsen third brake mount and one of the responses was regarding HF mobile. I wanted to add my positive experience with HF mobile, cannot find the article now.  Alan. K4LFP
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
