Thank you. The IPSCO holder allows use of THE standard STANT 54mm thermostat. Many choices in that size for cracking temperatures. I was targeting a stable oil temperature under my driving habits of between 185 and 195 F.
Except for GM  on the transmission thermostats, everyone  list the temperature of a thermostat starting with the 'cracking' temperature. Yes even GM. On trans stats list the fully open temperature. :dunno:
Katech is saying theirs starts to open at 174 F as a target but not higher than 181 F (+7) as the cracking temperature. Most stats then are fully open about 20 F higher. You got a dud or a mislabeled or miss-boxed unit. It's okay. He's making it right.
Most other brands of stats will give a cracking temperature target with a tolerance of +/-. Katech wants a hard floor.
Mine's never tossed a code but I never turn a key for under a 100 mile trip either so I never get two consecutive key cycles under 170 F.
Well, changed out the replacement last night.  Took the first Katech 174 out and it was marked at 79 degrees C.  New one arrived was identically marked.
Installed new one and did static test in driveway last evening..ambient about 80 degrees in shade.  Put the OBDLink MX on the plug and monitored the
temperatures.  Also put my hand on top radiator hose and waited for hot water to flow.   At about 168F, hot water began to flow through the top radiator hose
and continued to increase in temperature.  Cleaned up and put everything away for the next day.   Next morning, ambient 73F, cold start and also opening at 168 degrees F.  Easily 10 or 12 degrees hotter than the previous Katech 174.  This was about 10 minutes into the start cycle (AC off no fans).  Two minutes later it was down to 160F, two
minutes after that it was at 168F, two minutes later at 172F.
A lengthy road test (about 10 or 15 miles) through light city traffic and also 45 to 55 mph zones , keeping AC off, revealed ECT going from about 165 to 180 degrees
but mostly between 170 and 178 for the majority of the time.  Line at Drive-thru showed temps increasing to 200+ with fans coming on to bring temp down to high 170s.  Again, efficiency of this radiator with the V6 with air flow is impressive.  I sent the previous one back.  I think I'm done changing thermostats (but then I remember I still
have to do the 6L80 one with my Surecool kit).   Dan from Katech said they would refund my first purchase and test the return out.  Hope it works out. I'll just call it
the correct $150 thermostat installed with free labor...(shipping twice here and once back)....LOL Oh well...Happy engine....
  • 1 month later...
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
