Aside from my truck honking 3 times after I get in and close the door, the doors automatically unlock after I manually press the lock button on the door.
I've always had the habit of getting in my truck and locking the door before starting it up, but sometimes when I get in and press the lock a chime comes on and the doors unlock themselves. This seems kinda dangerous in a situation where someone would want to get in and lock the doors.
Why does it do this, what is the point of it, and how do I turn this off? Any help is appreciated.
Just now, mafd2 said:
Sounds like your spare fob is in the truck.
It's in my safe at home. I know the honking part is because of a scenario explained on another thread, but what about the locking (or I should say, unlocking) part? If the truck thinks the remote was forgotten inside, why does it go the extra step and prevent itself from locking from the inside?
It sounds to me like it is still trying to prevent you from locking the doors without the truck being started. I guess it goes the extra step because that's the way GM programmed it unfortunately. Why not just unlock the drivers door to get in? That way once you are in the only door that is unlocked is the driver door until you start the truck and lock it. Also try pushing the lock lever up by the door on the window sill. It will lock all of the doors as well.
Why does it honk 3 times as explained? It should only do that upon exit with the fob left in but not on entry.  Check all your door lock settings
No it's not programmed that way. I can use the passive button or the remote to enter then hit the lock button on remote or door before starting and I get no chirp or unlock.
Edited by mafd2
This is what I'm trying to do. Unlock the driver door to get in, close the door, and lock it by pushing the lock button on the door next to the door handle inside. But the truck doesn't like it. When I do this, the truck unlocks all the doors.
Let's say I stop to pump fuel. I get out, close the door, and proceed to start the fuel station up and pumping. Then I open the back door to clean some things out and then close it. Then I get back in the driver's seat to wait for the pump to finish. When I close the door, the truck honks 3 times. Then I try to lock the door and the truck unlocks all the doors.
I think I understand why the truck honks because it thinks I'm messing with my truck and then leaving when I close the doors even though the remote is in my pocket. But the really aggravating part is that when I lock the truck using the button inside the truck door itself, it unlocks everything and won't let me lock it.
I can lock mine before start. Just tried it. Go to settings, vehicle and check all lock, remote and passive settings.
  • 2 years later...
I have the same problem. There is no way to lock my vehicle from the button on the inside. It auto unlocks the whole truck after its pressed weather key is near or in the house. Dealer tried to figure it out but couldn't. Basically the inside lock button is for looks.
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
