on the rear of the stock radio it should be stamped into the metal the terminal designations.
You will need an integration module. Switched power, Bose amp(if equipped), steering wheel controls are "data communication" not simple power ground connections.
On 3/23/2022 at 9:46 AM, Ak_grown said:
Which wire is the dada wire color for the steering wheel controls im trying to hook mine up it say A 1 but don't see that wire
