I replaced my wireless charger a while back with the Gen 2 so it would charge my S10+. For some reason it will only charge it for like 3 minutes before it just...stops, and won't start again until I pick it up for 10 seconds and place it back down. Then it repeats the process, charges for a few and then randomly stops. My phone charges fine on normal charge pads. I take it out of the case to make sure it is in direct contact with the pad and it fits snug in it. Should I just look for a different aftermarket option?
I've actually never used mine. There has to be a ton of losses charging something that way? Anyways, I just plug it with the charging cord.
Yikes!  Mine quit working with my phone, when I put my Otterbox Cover on it, but my wife's phone works great.  I know that they will not recharge your phone if your battery is at/over like 95%, but that's not to say that if you put your phone on it at 90% that it won't charge until full.  I would try taking your phone cover off (if you have one), and see what happens.  The wireless charging system will/may not keep up with supplying power to your phone, while you're using it.  They all suck for recharging, especially while in use.
I've taken the case off before (though it is just a very slim case) and the phone by itself fits snugly into the console. Normal charging pads seem to work fine with/without the case...just wondering if maybe it is weak.
Not a huge deal but since getting the wireless android auto it drains my battery much quicker so I figured having it on the wireless pad would be ideal, guess that is not the case lol.
  • 3 weeks later...
On 3/29/2022 at 4:04 PM, PAPER said:
You guys can always upgrade to a after market fast charger that replaces the existing 1 in your armrest .
Here is a link to 1 on ebay , It doesn't seem to be to hard to switch them out . & I have seen them as low as $50.
 but I found this 1 with a quick search .
https://www.ebay.com/itm/313920601192?hash=item4917203c68:g:iX0AAOSwhDdiNyoo
Thanks for the link, maybe I'll give that a shot one of these days.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 417 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
