I have a 2014 L83 with a 6L80 4x4. Instead of rebuilding the trans, I’m considering moving up to a 6L90 if it’s possible. Does anyone have info about this or know of anyone who has done it?
  • Thanks 1
yes, its easy if your pre-2017 truck different tcus on these.  if you want the 6L90 get  one from a Camaro.
but the better upgrade for all the laybor would be a 4L75e, easier to rebuld these, and less mass in the 4 speed.
while everyone whos making big powa reccomends the heavy ass 8 speed, it shifts faster but draws more power because its just so f'n heavy
if your not making power just upgrade the stock 6L80 with updates and 6L90 parts, this would be less r&d work IMO
GM is running out of oil pumps for the 6L80/90 trannies, order a pump first to see if its available before attempting rebuild
Edited by pokismoki
  • Thanks 1
Thanks for the advice pokismoki. I have no interest in the 8 speed. I like the 6L80/90. Never thought of the 4L75 and I’m not sure what that would involve to make sure I keep 4x4. I’m not really looking for the fastest truck, just a dead nuts reliable workhorse. Really great info about the oil pump, thanks for sharing.
I’m running around 550 ft-lbs torque right now with plans to go higher. Spoke with Circle D Trans and TK Performance and a 6L80 rebuild is gonna be anywhere from $2500 - $4500. Then another grand for a converter.
I was thinking of just swapping my current tcm/valve assembly directly into the 6L90 to avoid any programming trouble. Update the tune for the 90 and fabricate the frame crossmember mounts. Trans output shaft would need to be custom ground for the transfer case along with a custom tail housing adapter. Last piece needed would be a slightly longer front driveshaft. I think that covers it but haven’t met anyone who completed it.
Now that I wrote all that out, I’m in agreement with you that rebuilding the 6L80 seems like the better option. Similar cost with a known result. Now to find an oil pump…
Edited by 300 Blackout
after you acquire the pump, be sure you install the new regulator valve, as the old design causes premature wear in the bore, and causes line pressure loss to the clutches, this area could possibly be where all the metal particles are coming from on low milage trans
after its built get it tuned with hptuners, turn off the tcc for 1-4th gear
Edited by pokismoki
  • 1 month later...
Do any of you know if there's a major difference between the 6l90 in the diesel trucks vs the other 6l90s? My 6l80 is trash and Reman Transmission has an already remanufactured one for like 2500 bucks with free shipping which is less than what I could have it rebuilt for but they also have remanned 6l90s for only like 150$ more, https://reman-transmission.com/transmission-codes/?code=6L90. The only thing is I think they only have them for the trucks they came in
    • I'd consider the 5.3 but not the 6.2. Last I heard, investigations were ongoing with the 6.2 failures and that there were continued failures even after engines were replaced.   I have a 3.0 diesel and regard it as the best option for a 1500. It's an excellent engine. Your preferences may differ.   Ford makes a good truck. Wouldn't steer you away from one.
    • Yeah I don’t leave ANYTHING just sitting supposedly maintaining my battery on a vehicle or RV for multiday periods. I connect a charger as needed to provide a full charge, then disconnect it and either monitor the battery or follow a set schedule for periodic charging.
    • Get the 5.3. I`m not a Ford guy.😉   I think these L84`s are less problematic than the L83`s. Certainly less than the L87.
    • I have finally paid off my mortgage and can now purchase a new truck. I would greatly appreciate any opinions on the purchase of a new 2026 GMC Denali 5.3L or 6.2L with the Denali reserve package. I am not interested in the 3.0L.  Or should I go buy a Ford?   Thank, John
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
