Some GM Wiring Problems
Hi
I have a 82 GMC 1500 long bed 5.7L.
I was driving around when my interior/gauge lights went out so I replaced the fuse and drove about 30 with everything working.
I get back it today and the gauge lights, dome light and parking lights dont work again but the fuse isnt blown. I though the parking lights and panel lights where different circuts and arent sure where to look for the problem.
I have checked the fused and played with the light switch but the dome lights dont come on with the door either.
Is there a specific area I should look at. College starts on monday and my truck needs to get working.
Thanks
Karl
Check your grounds too, they may be corroded and not always making a good connection. Also check the ground strap that goes between the engine and the firewall.
Bob G.
I am not for sure, but isn't the lighting power wire, that comes from the battery, on a Fusible Plug?
I would check that area. Hopefully you have a multipmeter or a 12volt test light to test with.
Cheers
