Hello, All -- New guy here.
2021 Silverado 1500 W/T
I am trying to learn the best location to route a wire from under the dash to under the hood.  ....The wire has an approx 5/16" diameter plug on the end (which can not be removed, cut or spliced).
Any suggestions?   ....I am not opposed to drilling a hole, but I don't want to cause any problems by hitting plenums, ducts, a/c, heater core, hoses, etc.
I have read many of the other threads, but don't see any suggestions.  ....Thanks for any help you can provide.
I'm looking to do the same for a rear camera mounted on my Lear Truck cap. In my case I probably need to route under the floor. That said I need to find a good location for 12V and ground under my dash. Let me know of any suggestions.
Go to https://www.gmupfitter.com/technical-bulletins/?_sft_category=2020&_sfm_technical_bulletin_vehicle=Silverado%2FSierra&_sfm_technical_bulletin_type=1500 and read the section titled Power Cable installation/routing on page 4 and see figures 6 and 7.
If I can run a cable into the cab you should be able to run one out.
For PBrown1: you can a cable through the floor pan on the driver's side.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and maybe memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.
