So today I realized my rear speakers which are in the doors of course are not working 09 Avalanche LT. Pretty sure they were fine just the other day cause I turned it up for a good tune but not sure, still sounds good but just HATE when stuff doesn't work as it's designed. It's only my wife and I driving this truck so pretty sure she wouldn't have done any harm.
What could the problem be? any help would be greatly appreciated.Cheers.
OEM speakers are notorious for going bad...strange that they both went out at the same time though
First, check FADER settings and make sure it hasn't been adjusted to just play through front speakers.  You can check fuses (I think they're #41 and 42 in the underhood fuse block) and make sure they're good, but if you're getting sound from the other speakers, the fuses shouldn't be a problem.  If FADER settings are set to go through front and rear speakers, it's time to start pulling door panels and checking speakers.  You can pull a speaker from front door and hook up to the rear door and see if it works.  If it does, then proceed to checking wiring going through the doors.
paper cone factory speaker and an 09 must have been its time. do you have the factory Bose amp? either way best bet would remove door panel and check speaker.do you have a multimeter? if you feel more comfortable removing the radio and checking wires behind the radio over removing the door panel you could go that route also. but if the speakers are blown might as well remove door panels.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
