What is the factory rear block size for a 2018 Chevrolet RWD
I want to take it out so my truck leans a little and the front is a little higher, but i do not want the squat look
I think the last time I measured the factory rear lift block they were around 1.3in high. I removed them on several of my half ton trucks to drop the rear down so it's more level.
Since you posted in the HD section, I'm assuming you have an HD truck. If that's the case, your truck doesn't have a factory rear block. The only way to lower the rear is with lowering shackles.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 671 Guests (See full list)
