I currently have a 2" front level with a 1.5" rear block on 33s.  Considering the rough country 3.5" lift but I tow a lot so im afraid to upsize tires too much and ruin axle ratio.  Does anyone have pics of 33s with a 3.5" lift?   Just curious if it would look okay or if would need 34s to really pull it off.  Thanks!
I've seen it, they look small in my opinion, but mine doesn't count.  Going to a 34" tire will have almost no noticeable difference on effective ratio since the 8 and 10spds have such a short first few gears.  The only real difference you might notices is the additional weight of the 34" tires as they will most likely be E rated and considerably heavier, but they will also handle the towing significantly better.
Edited by Gangly
Here is a thread that has a couple of images with a 4" lift on stock wheels and tires. I do not personally think they look that bad.
  • Thanks 1
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 485 Guests (See full list)
