18 hours ago, KevinRC said:
Oh so now 20 minutes.
Kevin - you'll notice that in my post of Wednesday October 26th I said, "about 15 minutes."  I can't say precisely how long it took to do the actual work, but I can say that, out of curiosity, I did zero and start my wristwatch's stopwatch feature at the moment when I went to my toolbox to grab my soldering gun, solder, and other tools that I knew I would need, and then stopped it after completing the job and putting my tools away.  It read just shy of 20 minutes, and that's why I concluded that the actual work took about 15 minutes, but definitely no more than 20.  It's all in how you look at the job, Kevin.  If one is only interested in how long it takes to remove, disassemble, repair, reassemble, and reinsert the cluster, then it took me about 15 minutes or so.  If you want to include the time to prepare by getting tools ready, and put them away afterwards, then the total time for the job would be closer to 20 minutes.  I suppose one could also add the time it would take to watch the two YouTube videos  which I suggested earlier, the first one being 2:39 and the second being 8:29, and perhaps also add in the time it would take to have booted up the computer, gone online and into YouTube, and then shut the computer down afterwards.  With everything figured in, it would come to maybe 30 to 35 minutes.  I don't know how you gauged the time it took to remove and replace your cluster, as you didn't explain that.  Of course, if you were figuring total time, you would also have to include phoning parts stores or doing an online search to find the cluster and either order it or drive somewhere to pick it up.
No matter how you figured your time involved, I'd say that 30 minutes is quite reasonably efficient for the task at hand, especially if you never had to do a similar job before.  I just think it is too bad that you spent $170 for a new cluster when you still had to remove and replace the unit, which is where most of the repair time is involved.  Disassembling the cluster once it has been removed, reflowing the solder on the 7 resistors, and reassembling the unit, was actually quite easy and took just a few minutes.  One thing to watch out for, for folks wanting to do the reflow trick, and which is not stated in the videos, is that you should take a small screwdriver, or other small tool, and use it to press down each resistor to hold it in place while you are reflowing its solder joints.  Otherwise, when you lift your soldering iron away after melting the solder, the resistor will tend to move a bit and no longer be aligned properly.  Another thing to be careful with is in removing the gauge indicators.  If you grab and pull on them with your fingers or needle-nose pliers, or try to pry them off with a screwdriver, you are likely to break one or more.  I cannot remember now exactly what tool I used, but I believe it was one which had a v-notch so that the tool could be inserted below the indicator and brought up to touch the shaft which the indictor is mounted on.  Gently lifting straight up allowed the indicators to be removed easily and safely.  I may well have used my mini pry bar, which is similar to this one:  https://www.amazon.com/Vaughan-460-04-222-Mini-Bar-2-Inch/dp/B00G0ORV6Q/ref=sr_1_1?crid=2PKUFOOAKMAXB&keywords=Bon+Vaughan+460-04+Mini-Bar%2C+5+1%2F2-Inch+(37-742)&qid=1667069718&sprefix=bon+vaughan+460-04+mini-bar%2C+5+1%2F2-inch+37-742+%2Caps%2C106&sr=8-1
No worries, I was just hesitant to once the cluster was out and the further disassembly was what made me me pause.The videos that I watched, while very good, made me feel  a tad leery about taking it apart just to get to the re-flow aspect.  Other than that, I was ready to try it. But like I said, I bailed.
I might had tried it had I not had so many other issues to address.
Thank you.
  • Thanks 1
I order it from carparts.com and gave them the mileage and then the manufacturer "Cardone" pre-programmed it.
Funny thing though, I had told the person at carparts.com that the mileage was 208,130 and it came programmed as 200,813. Oh well,, I gained (or lost) almost 8K.....😁
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 498 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
