Got a question hoping to pick someone's brain for a min? I have a 2011 Silverado 5.3 4x4 flex fuel 230k on the clock. Back earlier this year, it collapsed a lifter. Local auto parts only had a couple parts to complete the task. So I replaced 2 lifters (all they had) it was number 7 lifter. Replaced all the push rod for that side. Got everything back up and running everything seemed smooth running but my oil pressure was lower than usual. So went back in a few weeks later and replace the pick up tube gasket. Looked better but still not right. Replaced the oil pressure sensor and screen, Replaced all gaskets on everything I dug in to.....I got no oil leaks. I am just assuming I have a weak oil pump at this point. Truck will start up with 40-45 psi. Once it starts warming up it drops as low as 18-22 psi. Oil pump or am I leaning the wrong way?
A warm idle at 20psi is more than fine.
If your cruising pressure is 35-40psi and full throttle is 50ish, it's just fine.
there is a pressure relief valve for the afm located in the oil pan, if it sticks open you will loose approx 5-8psi oil pressure to the top of the engine..if you remove the oil filter you can use a long straight pick to unseat the valve and blow out debris.
if that doesnt change anything, take out the oil pressure switch and screen below it and check for debris..
if you have access to the oil filter adapter to install a pressure gauge there, that will tell you if the oil pump is producing enough pressure, thats actually where i start but thats usually a dealer only tool that i know of...should have at least 55psi from the pump
Dmsooter, I have a 2011, 141k miles, same truck you have.  That happened to me also in the spring.  Running at hwy speed it was 21-22 psi.  Only when I raced the engine up did it go to 30.  Also, my check engine light came on signaling oil sensor.  I had it changed.  I got to 30psi hwy speed, 22 idle speed.  Another member of this forum said he'd had it years ago.  He changed oil & filter and all was good.  So, I tried that --- cheaper than hit & miss tries at a shop.  I changed oil & filter and Bingo.  At start up 42-45 or so.  After warming up hwy speed settles around 40, idle its at 30 (but sometimes goes to 21, which I do NOT understand).  Most of the time idle is 30psi though.  Bottom line:  when I changed o8il & new filter it all improved.  Why?  I don't have a clue.  My guess is something in the old filter, just a guess.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 396 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
