Hi,
I have a 2018 Silverado LT 4WD with about 26,000 miles on it.  Whenever i am full turn on the steering wheel be it full left or full right i get clicking noises from what I can tell on both front sides of the truck.  I really only hear it if i am in reverse and the steering is fully cranked like when i am backing into my garage.  I will hear it once in a while when i am turning full tilt into my driveway forward.  You will hear the drivers front click a few times and then the passenger side will click a few times.
No noise when turning the wheel when the truck is not moving.  Only starts once the truck is moving slowly.  Driving normal there is no noise at all.
Noise is still there if vehicle is in 2WD, Auto or 4WD.
Its not a slow click.  At 2mph full turn you will hear tick tick tick tick pretty quickly and then it goes away.
Is it my CV joints on both sides?  My bumper to bumper warranty is gone because of age, but wondering if covered by powertrain warranty.
I cant tell if its CV joints, brakes, the wheels, etc.
Anyone else have similar issues?  I will see if i can get someone to record the sound.
Ok i pulled 2 videos from my camera where you can hear the ticking/clicking sound.  You hear basically tick tick tick and then you can hear where i shift from either drive to reverse or reverse to drive, so that part ignore.
Does it still sound like CV joints to you guys?
  • 1 month later...
Any update? Battling this concern right now. Just spent $300 on a new cv axle. Didn't change a thing. Mine only clicks when backing and turning to the left. The sound is coming from driver front.
So apparently its my wheels or the wheel bearings making the noise.  If i rotate my tires, or if i loosen the lug nuts and retorque them, the sound goes away for a couple weeks but then comes back.  Weirdest thing ever, but someone on the facebook group mentioned it to me and as soon as I did it the sound went away for a couple weeks.  It came back, but i just loosened my lug nuts and retorqued them over the weekend and its gone again.  Im assuming will be back again.
This is certainly not what we like to hear, oachalon.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2018 Chevrolet Silverado LT. To do so, please send an email to [email protected] with ATTN: oachalon/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
    • Thank You Another JR, I watched the transmission temp the highest was 214, the engine temp seemed normal.  Hoping not a valve body issue, but...
    • dexos began as an effort for GM to control the oil change market because the Quick Lube Industry was eating into dealer service department profits big time. So they attempted to get other oem’s to develop standards as well and that would make it hard for Quick Lubes to compete because all the oems would be different. GM faced lot of industry push-back, mostly the quick-lube industry and they went to licenses. Still GM it making a ton of money (est'd 30-40 million in 2025) off the license structure as they charge a hefty fee to get oil tested then require a royalty on ALL gallons sold applicable to GM vehicles.
    • Those are parts changers. It can get expensive though. I was a mechanic for 30 yrs. My truck has made this noise since new. I really don`t know what it is. It really doesn`t bother me. I`m still in warranty but have not brought it to the dealer.   I`m not buying the oil pump prime thing. Screw the TSB. I believe it`s in the trans pump gears. They rattle when that piss poor ULV oil drains off after a while. I believe those sharp tooth gears, with backlash, can rattle when dry. Not a vane style oil pump. Wonder who`s right? Me, or the TSB?🤔   Maybe I`m wrong?
    • Sounds about right. I miss the days of mechanics lol.
    • On the PCM side, blue PCM connector, pin 18, solid gray color (no stripe) wire circuit 435.  That is the EGR low circuit which an issue on that line (be it the wiring, the PCM or the EGR valve or system performance) will trigger P0401 when it tests that code.     There is also a VERY old TSB that states to make sure you clear the DTCs ANY time the PCM is unplugged, reprogrammed, or if the EGR valve is unplugged or replaced as the PCM has an auto zero function in the PCM for the EGR pintle data   61-65-59: SMU - SECTION 6E - ENGINE CONTROLS - CLEAR DTC'S - (Nov 25, 1996)   "CLEAR ANY DTCS FROM THE VCM ANYTIME AFTER DOING VCM REPLACEMENT/ PROGRAMMING, TURNING THE IGNITION ON WHILE THE EGR VALVE IS DISCONNECTED, OR REPLACING THE EGR VALVE."   Some diagnostic aid notes in the GM diag on P0401 for a 1995 S10 Blazer:   Diagnostic Aids Notice: In order to prevent further damage if the EGR valve shows signs of excessive heat, check the exhaust system for blockage (possibly a plugged converter) using the procedure found on the restricted exhaust system check. If the exhaust system is restricted, repair the cause; one of which might be an injector which is open due to one of the following reasons: Stuck Grounded driver circuit Check the oil for possible fuel contamination if a stuck open fuel injector is found. Poor connection or damaged harness - Inspect VCM harness connectors for the following conditions: Backed out terminal BL 18 Improper mating Broken locks Improperly formed or damaged terminal Poor terminal to wire connection Damaged harness Intermittent test - If connections and harness check OK, monitor a digital voltmeter connected between terminal BL 18 and ground while moving related connectors and wiring harness. If the failure is induced, the voltage reading will change.
