PIAA Xtreme White Bulbs
SnakeEyeSS
FYI: If you guys don't know, Sealed beam headlight didn't vut it in eurpose, so Hella Made the H4 headlamp. they most cars with 5 3/4 round sealed beams, if you have a car like this and wsh to upgrade. This review was made for the BMW boards I visit, but still review the PIAA Xtreme White bulbs, available in (9005 and 9006 varietys.
H4/PIAA Review
ITem & Source:
(2) Hella H4 headlights: Classicgarage.com $37 each
(1) Pair of PIAA H4 Xtreme White bulbs: BavAuto $69.95
Total cost including shipping $160.
Conversion:
This is a DIRECT swap, just like you changing a regular headlight. The noticeable difference is that the H4's lense sticks out a bit more, and now you can change bulbs w/o changing the whole unit.
Product "look":
Classic Garage supplies you with a generic H4 blub for each H4 you buy, it's included in the price. I wanted to get as close to an HID look/output as I could without shelling out the extra cash, so I ordered the PIAA Xreme White's from BavAuto(not to be confused with the SuperWhites). As for the look of the light, I had a a second person come over to look at the lights. He agreed, these look really close like HID's. You may be wary of getting a "Cheap clue" look that a lot of cars have when they go buy the $8 dollar "cool blue" lights at wal-Mart. this is NOT that kind of blue, the H4/PIAA Xtreme's yield a HID blue. IT's not a
"cheap blue" or a dark blue. It's a very bright whie light with a blue hue to it. When I was behind white cars or near white roadsigns, it look like the sun of shining on them, it was a very clean, clear light. The father away you get, the more they look like HID's. My frined was impressed, as he was wondering if there was a bulb that could achieve the look, and he thinks this one does it. HID's have the look of 4300K, PIAA Xtreme Whites look of 4150K, and sealed beams around 3000K. so as you can see, the look is close to HID.
Product Performance:
There is instantly a noticeable increase in lighting. For the moment you turn it on in the garage and see the prue white light off the garage wall, you know its better. They field of view is wider, taller, and "farther"(more distance). All this thansk to the H4's. The field of view is also much more clear and visible, thansk to the PIAA's. As I went on the road, not one person flashed their highs, so I'm guessing my lights are adjusted right(or pointing in totally the wrong way, lol). When I had the sealed beams, I always noticed what my field of view was, when testing the H4/PIAA on the raod , I found myself not even noticeing the field of view. This is good, because the limits have increasedso much, it's like its day time in my field of view, I can see everything quite well. When backed into the garage withs lights on, My neighbors graage door is lit up like its daytime. With the lights shining trhough the top of the glass part of the door, it even looked like there were lights on inside!
conclusion:
I am very happy with the upgrade, and everyone whoe took the time to look at the new headlights(some relative were over during the conversion, they check them out when I was done) shieled their eyes when in front of the car with the lights on. If I ever own another e30, I will deffinately do this upgrade. It's almost HID's for much less. I hope answered your guys questions!
I did the H4 conversion on my F-car and the difference is amazing. Old yellow headlights gone, nice bright white (with a better reflector) and more modern look.
Though I don't drive it much at night, the pattern is much improved and it is not too bright that it bothers oncoming traffic. The lights are white without the "cheap" blue tint, just a little.
    mark2
    mark2
  • Who's Online   5 Members, 0 Anonymous, 648 Guests (See full list)
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
