Hey Fellas
About to do my rear rotors and pad. Would like to know the proper torque spec on caliper brakets and slide pins as well.  Thanks!
Edited by Matt Ziprick
This is from earlier HD trucks but should be roughly the same:
2 brake caliper mounting bolts to 108 Nm (80 ft. lbs.) .
Caliper Mounting Bracket to Knuckle, Front (15 series) 175 Nm (129 ft. lbs.)
Caliper Mounting Bracket to Knuckle, Front (25/35 series) 300 Nm (221 ft. lbs.)
Brake Caliper Mounting Bolt Rear (15 series) 42 Nm (31 ft. lbs.)
Brake Caliper Mounting Bolt Rear (25/35 series) 108 Nm (80 ft. lbs.)
Caliper Mounting Bracket Bolt Rear (JC5/JH5) 200 Nm (148 ft. lbs.)
Caliper Mounting Bracket Bolt Rear (JH6) 165 Nm (122 ft. lbs.)
Caliper Mounting Bracket Bolt Rear (JH7) 300 Nm (221 ft. lbs.)
Caliper Mounting Bracket Bolt Rear (NYS) 200 Nm (148 ft. lbs.)
On 8/15/2022 at 1:16 PM, Matt Ziprick said:
Hey Fellas
Bracket bolts 221ft.lbs.  Pins 77ft.lbs.
16 hours ago, CamGTP said:
Couple braps with the impact.
3 or 4 ugga duggas is usually good
    erickn520
    erickn520
  • Who's Online   5 Members, 0 Anonymous, 501 Guests (See full list)
