Hi,
after a while i have now again a problem with my truck. I will try to explain what the problem is.
if i accelerate from stop to 35mph, the rpm start going up to 1200 and then there is a hard jump about 200rpm to 1400.
This only happens from stop, not from slow speed. I had this morning a problem which disappear but the speedometer showed the wrong speed till 25mph and then it jumped up to the right speed, while i had this problem the transmission worked okay, after work started the truck and the RPM jump is back and the speedometer is correct.
I am not sure, if its a engine or transmission problem, there are no dtc in the truck.
I am happy to get some ideas what the problem might be as i am stucked.
Thanks
Pierre
Transmission issues. Likely time to rebuild. I'd not keep driving like that as it'll just get worse. Take it to a shop for diagnosis. Sounds like torque convertor or pump issues
Hi,
Problem is to find some one in Germany wo want to touch those cars.
What confused me is that its not happening all the time and what i saw in the data is that the pedal position is stady but the throttle position is dropping, which makes no sense for me.
Also some information which i missed, is the car was staying for 10 days as i had contact to a person who had Covid, so i didn’t left the house, when i parked the car, all good and after that it started.
Thanks
Pierre
Hi,
is it possible that this is a problem with the speed sensor. When i start, i can see that the speed sensor is not recognising the speed correctly till about 25mph then it kicks in. Where did the speed sensor sitting?
Thanks
Pierre
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
