I have been getting a verbal "GPS signal lost" message intermittently while driving.  It doesn't appear to affect my Navigation.  Is anyone else experiencing this?
Thank you in advance for any responses.
Yes, It's happening to me all of the time. At least 3 times per trip. Allso does anybody know how to turn off the onstar message that comes up at every start up? I also want to permanently turn off the engine stop switch.
Dave
I also get the verbal "GPS signal lost". I believe it's a update. I use the Androi Auto feature exclusively. It does lose connection from time to time. Or freeze. It can't be every cable I try.
Thanks for the link for the auto stop eliminator. I am going on a trip Friday so I think that I will invest when I get back.
Thanks again.
I too have been receiving the "GPS signal lost", error message?  As for disabling the Auto Stop / Start "feature", I installed the Auto Stop Eliminator on my 2021 Silverado a year ago.  It has worked perfectly as advertised.  It was easy to install after I watched the UTube video several times.  You will need to get passed the pucker factor of removing the dash trim and then the remainder of the install is easy.
We apologize for this inconvenience. Depending on where you live or where you travel, coverage can vary. Please see OnStar's coverage map here: https://www.onstar.com/us/en/coverage_map. If you believe there is a connectivity error between OnStar's servers and your vehicle, we highly recommend pushing the blue OnStar button in your vehicle to refresh the signal. A live OnStar Advisor will be able to walk you through any additional troubleshooting to ensure your hardware is working as designed. If you have any further questions please send us email to [email protected] with ATTN: [Forum Username]/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Thanks for all the feedback.  Because of that, I was able to return to my dealership and let them know that I wasn't the only one experiencing this issue.  They investigated further and got back to me with the explanation that perhaps water is getting into the cellular antenna that is on the roof of my truck.  I was told to have the service technicians explore this further when I bring the truck in for my next oil change.  It kind of makes sense, if I have correlated the frequency of the message to the proximity of my last car wash correctly.  I hope this helps!
Robert,
Please keep us updated. I got it after it rained and I was not getting that when it was dry. You may be on to something.
I have both the GPS signal lost and the SD CARD removed error on my 2022 AT4 Limited. I was told "engineering" is looking into that it's a known issue. If it was a known issue I figured I'd see more posts about it in here.
  • 1 month later...
I have a 2019 AT4 that just started having sd card problems. It says SD card removed.
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,386 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
