Has anyone installed a set on a 2023 with the new diesel? Amp hasn’t updated their website. I spoke with a representative at Auto Anything and they recommended the Go Rhino E-Boards. The part# for the 2022 refresh and the 2023 are the same so I’m hoping they’re the same and ordered them.
For anyone else searching, they’re the same part# as the 2022 refresh model. Amp updated their site. Now we just have to wait until they get some back in stock. One vendor is saying at least mid January.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,121 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
