Hello new member here,
Im looking to see if anyone has repaired a bent seat frame after a wreck?
Also looking for electrical diagrams/info to understand what I need to keep for a swap into a 1970. Would like to keep the heated seat function and obviously be able to adjust the seat position. Was not expecting such a wiring harness! DS has a box where several things plug into but it doesnt look like there is one on the PS. Maybe thats the seat memory function?
Truck was a 2017, I think it just had heated seats. Not 100% sure because I got these from a junk yard and they pulled it.
Vin: 1GCVKSEC7HZ317330
Thanks for the help
FYI for the next person -  I ended up just cutting the harness connector off and taking the seat apart to see where everything went. Found out the seat heaters are controlled with a combination of the controls on the dash, BCM and the climate module under the passenger seat. Its easier to just install aftermarket heaters. Bypass worked to control adjustments.
Ordered lower seat frame from the dealer for $390. Too many moving pieces to attempt to bend back for me.
