I have a 2018 Gmc Sierra 2500 and everytime it rains and I drive my truck it tells me to service stabilitrak then the abs and traction control light comes on does anyone know what I should look for that could be messed up?
You may have a water leak at the roof antenna that trickles down to drivers side dash. Pull the fuse cover on that side & see if you see any rust
I used to get those alarms for years and the dealer replaced the brake level reservoir switch and I have never seen it come back in.
Yotaman
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 784 Guests (See full list)
