So Rpm’s started going crazy we had it parked for a couple days . Today we tried get it into gm but didn’t make it. You can drive it at a certain rpm but then it will go crazy and like just not go. Can’t be put into reverse when this happens. if you turn off the car and turn it back on it will run but then same thing happens.
2017 gmc sierra single cab . 5.3L 2x4
Edited by Conejabelica
Any information about the truck at all would be very helpful, otherwise all you will get are guesses and sarcastic comments.
20 minutes ago, asilverblazer said:
While you are gathering pertinent information, check engine light ought to be on, so get a code reader and see what codes come up.
No codes on reader. We’ve already done that. No check engine light either
Does the check engine light function at initial start up?
What does this mean? The gear selector cannot be put in the reverse position? If put in the reverse position what does the gear indicator do? Does the lever go into reverse and the indicator indicate reverse but nothing happens?
So far I'd expect a torque converter and transmission rebuild is in order. Does the truck otherwise start and run fine? Mileage on the odometer?
Any grinding or other odd noises?
Edited by asilverblazer
Correct it will be in the reverse gear . But does not move. weird part is if you turn off the truck and turn it back on you can go in reverse.
the truck runs good . No issues with it till now . It has like 990000
its never had any odd noises. It was running good then like one day it just decided to start shifting weirdly. And now this
The only thing left that might be 'simple' is check all electrical connections to the transmission. If it is not a mechanical failure that requires rebuild it is an electrical issue that a more sophisticated diagnostic tool should uncover.
In any case, I would expect a significant number of dash warnings... in other words, if you don't see anything external, its going to need to go to a shop.
After you turn it off and turn it on and reverse works, does reverse cut back out again after you start moving?
57 minutes ago, Conejabelica said:
Yes
Transmission is highly likely.  We got a 2018 right now doing that.  Converter was smoked which sent debris everywhere and smoked the pump.  It also smoked the 4-5-6 clutch pack and chipped some hard parts somehow.  Curretly getting rebuilt.
Time to have the transmission pulled and gone through.
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 656 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
