I have 22" stock wheels now, and tried a friend's stock 20" wheels, which improved the ride noticeably. And, contrary to what I would have thought, even around hard corners the 20" were infinitely better, even though the 18" had stock AT Duehlers with 29,0000 miles on them! I now wonder if 18" wheels would be even better, and am curious as to whether or not any of you run 18"wheels on on your Denali, or have tried them. Feedback, experience, opinions welcome.
I went from the factory 20's down to 18's and definitely preferred the ride of the 18" wheel and tire combo.  The additional sidewall helped smooth things out, especially on dirt roads and improperly maintained city streets.
Thanks for chiming in. Looks like you have an Silverado LT whereas I have a Denali, so I wonder how 18" would affect my adaptive ride control shocks.
BTW, are those wheels in your profile pic GMC wheels or Chevy?
The adaptive ride shocks are basically accounting for axle movement(shock compression) and taller sidewalls will absorb more irregularities, minimizing axle movement.
Basically, you have more sidewall so your ride would be smoother/softer, regardless of your adaptive ride shocks.
Edited by Gangly
Thanks for that. Do you think 18s will affect my gas mileage?
In case you missed it, are the wheels in your profile pic GMC or Chevy wheels? I'm wondering how they would look on my Silver Sierra.
The wheels in my profile pic are GMC factory 18" wheels that came off a GMC AT4.  I used my bowtie caps from my fatory 20" wheels instead of the GMC caps, that might be where some confusion comes from.  Google "Silver AT4" and you will probably find a bunch AT4's with those wheels.
The factory wheel offerings are close enough in weight that the gas mileage wont be affected as long as the overall tire diameter is close to the same and you stick with C rated tires.  Stepping up to E rated tires will increase your rotational mass and you will see a small drop, a little less than 1mpg usually.
If I went to 18s, I think I might have to step up to 70 sidewall because I think the stock 65 on 18s is significantly smaller than my stock 32.9" diameter on 22" 50 series tires. 20" rims are 60 series at 33", and 70 series on 18s is 33.2".
I thought those wheels of your looked more like GMC wheels than Chevy. Now I know why. 😉
The stock size on the 18's is a hair over 32", so yes, you would need to have a wider tire in the 65 series, or go to a 70 or even 75 series with stock width.
275/65/18 will put you right about 32.1" diameter
285/65/18 will put you right about 32.6" diameter
275/70/18 will put you right about 33.2" diameter
I'm after more comfort, and don't go offroad, except when I sometimes have to drive on the dirt shoreline of a lake to get to a launch ramp to launch my bass boat, which is not often, so I'm trying to stay with all-season tires like the Michelin LTX Defender. The problem I'm finding is that when I try to go bigger to get closer to my stock 32.9" diameter, I get into an E-rated tire. I don't have that problem if I move to a 20" wheel instead. Thoughts?
E rated tires are not comfortable unless you air down, or have a significant load.  The Nitto Terra Grappler G2 is an SL rated tire in 295/70/18, but you are correct regarding most tires in this size range being E rated.
That size tire won't work for me because I am not lifted.
Since you had 20's you faced the same issue I am facing, because your stock tire was a 33" diameter, wasn't it?. What tires are you running on your 18s? And, how did you recalibrate for the diameter difference?
I just took my 18's off and put my 20's back on because the duratracs got too loud.  I'll be putting 34"-35" tires on the 18's shortly, but I'll wait until summertime to do so.  The Silverado's can run all of the sizes mentioned above without rubbing and without a lift.  The wheel well on GMC's is smaller so y'all run into more problems with tire fitment, but you should still be fine with anything around 34" diameter.
I never recalibrated for the difference.  My speedometer was off by 3 mph at 70 mph, I just corrected my driving accordingly.
Nice that you are able to switch back and forth between sizes when you need to.
I didn't know the thing about Silverado wheel wells vs. Sierra wheel wells. And, at first glance it doesn't look like there's much room for a bigger tire, so the add'l info about the tires you previously mentioned is helpful.
So going to the 18s made your speedo read faster by 3mph, correct?
Edited by MrLeadFoot
Yes, the TB and AT4 with 18" wheels actually have ~32" Duratracs.  GM's off road package has smaller tires than the non off road package, ironic huh?
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 353 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
