Hello, ive got a 2016 GMC sierra with the 5.3L. Ive had this code P0308 thrown 3 times now and every time the CEL goes off for it its when ive had my cruise control set between 110-120kph on the highway. I feel no loss in power and the truck runs perfectly fine. I just had an oil change done and got my mechanic to replace all the spark plugs and wires and it still came back again. Im starting to think it may have something to do with the AFM because its only happened under light load and at steady highway speeds. Just trying to figure out what the next step would in trying too solve this issue. Any feedback is appreciated
It takes several times of it happening to keep the cel on. Did you check the compression on the cylinders?
Also check that the coils are working at full capacity and check for proper fuel psi.
If you can, try swapping coil and wire from cylinder #8 to cylinder #6 and see if it changes to a P0306, since P0308 is misfire cylinder #8), cylinder #8 is not a AFM cylinder, 1, 4, 6, 7 are the AFM cyl.
  • 5 months later...
I've got the same issue, but on a 6.2L. The truck started idling rough and the CEL came on and gave a P0308...changed the plugs, coils, and wires but the light came back. It gave me a P219B so I thought maybe a fuel injector...ran some injector cleaner through it. Didn't work...I changed the MAP and MAF sensors and it still idles rough. I ran a can of Sea Foam through the intake and drove it with "spirited acceleration".  Now it's giving me a P0106 (Manifold Air Pressure Sensor problem). I swapped out the new sensor for another new sensor and it still gives me the same P0106, an occasional P050D and an occasional P0308. Any ideas what I'm chasing?
P050D = Injectors.  I'd do all 8 and don't forget the one time use fuel pipes.  See what happens after that.
Had to trade in the truck. It was deep in the engine and much more than I was willing to pay. Not to mention the transmission was always a PITA.
    Matt Parker
    Matt Parker
  • Who's Online   2 Members, 0 Anonymous, 781 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
