I'm looking at putting some 14-18 mirrors on my 05 tahoe and I can't find the pinout for the mirrors anywhere. I'm putting in heated, power folding mirrors with the blinkers in the mirror as well. Does anyone know where I can find the pinout for the mirrors? Same goes for my 05 mirrors, just trying to figure out which colors go to what, thank you!
