Hey all, my 2002 Silverado 2500HD 8.1L w/ Allison transmission recently started making an intermittent but rhythmic squeaking/scratching noise that seems to be coming from engine internals. Video of engine noise https://drive.google.com/drive/folders/1ANVafHeQLibrg7velXbiScdqP4Fb3hlF
Noise is about the same through rpm range. Engine has 240k on it, no aftermarket modifications. Fearing lifter failure I went ahead and pulled the intake manifold to inspect lifters, did not see any loose retaining clips and felt all pushrods, none have excessive play. Attached pictures of lifters. Cam lobes that I could see looked fine. When I get off work I will spin the engine over, feel all pushrods for play as the bad one could be compressed and not showing play currently. Also will pull the valve covers and inspect springs/rockers. I know I jumped the gun by tearing down but has anyone else had experience with this noise? Sound seems to be coming from top end, not a deep noise like bottom end. I do have a one snapped off exhaust manifold bolt, rest are tight but doesn't sound like an exhaust leak to me. Appreciate any input thanks.
Found it, looks like a lifter failed and destroyed a lobe on the Camshaft. Also slightly bent pushrod and scoring on another cam lobe. From how deep the groove in the cam is I assume there has to be metal debris in the engine. Seems i should replace the long block or rebuild this engine entirely short block and all. Only other option I can think of is pulling and cleaning put the oil pan, replacing just lifters/pushrods/cam and praying no oil galleys get blocked.. Any advise appreciated!
In all honestly, that is a pretty common failure to see on the camshaft.
Also pretty common that if you just look at the cam bearings, they will be worn. But it you don't look at them, then they won't ever be bad. It's the game we play when swapping LS camshafts lol.
If it was me I'd rolling the dice. Think about it a little, it took a long time for the lobe to get that bad, that's not a 1-2 miles worth of run time failure. It's been chewing that lobe up for a long long time. Slap a new camshaft in there, new lifters and keep running it.
But if you have time and don't mind the truck being down, then repair what you got and then some. Send it out to be cleaned up, install new camshaft bearings and new rod/main bearings. That's usually cheaper than a complete long block.
I think Cam's approach is pretty on with this.  New cam and lifters and run it, or pull it for cleaning, new bearings (cam, main and rods), cam and lifters.
The Gen 5 LT camshafts we've changed at work, only one so far needed camshaft bearings.  And the lobes on these looked worse than how yours does.  Far more pitting/delamination and nowhere near 240k miles.  More like 50-100k.  Cop Tahoe smoked a non AFM cylinder lobe at 78k.
Edited by newdude
Okay gotcha, truck still had good oil pressure so i will try not to look at the cam bearings! 😆 I will be going that route and doing cam/lifters/pushrods and do a crankcase oil flush. I have heard bad stories about remanufactured lifters being lower quality, any brand would you suggest?
Left a rag in intake runner, got sucked in and probably bent valves and kissed the piston... Thats what I get for being an idiot.
Edited by Waffeey
An idiot
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,951 Guests (See full list)
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
