I have a question  my rear sliding window will open with the switch I can hear relay clicking  when I go to close window I have nothing no clicking.  I do have charging pad in center console. Can someone tell me were relays are located  One relay thats clicking is somewhere down on right side of fuse panel  I cant find it.  all fuses are good also I have even replaced the switch still not working
Have you seen this video?
1 hour ago, rick mccarter said:
thanks for the video  but I do not the charging pad on my console  I have the pull down console
Sorry but you said you had the charging pad in console on your 1st post.
Are you aware that relay #51 is the Rear Slide window open and #52 is the close? These are in the Passenger side fuse box.
Edited by rav3
ya I did sorry about that  ya relays click when opening window  but when you hit the switch to close  nothing no clicks of any noise  I also replaced the switch  I checked the motor  when jumped it turn both ways
Replace #52
ok i ll try that
