Rear speakers for 97 Ex. Cab
I've got some Infinity 6x9's. At this point for time and $$, I only want to add these to the stock deck. I thought about cutting a hole in the plastic area that covers the rear speakers and then mounting these speakers in the holes to the plastic. I tried to remove the door panels, but after an hour I gave up because I would have broken something as I was getting frustrated :loser: ! I think it would look really nice, the speakers have their own black metal covers. I'm just afraid that I would cut the plastic and then couldn't get the old speakers out, or something would keep the new ones from mounting in the hole I cut in the plastic. If this idea won't work I guess I could just get 2 boxes and mount them in that. I'd like to keep the floor area empty cause I was wanting to add a 10" JBL sub that I've also got this spring after I buy a new amp. Any ideas appreciated. Also, if I have to just set the 6x9's in boxes on the floor, what wires coming out of the back of the deck are to the rear speakers or is there a better place to splice into them? Thanks, Chris
Ok, you are trying to put them in the rear pillars? I am not sure there is even room there for a 6"x9". For sure there is nor without cutting into the metal. The original speakers are 4"x6".
Why are you trying to take off the door panels? I must be missing something here.
My original plans were to remove the stock rear speakers, then figure out a way to mount the 6x9's. That's where I was wanting to remove the rear 3rd door plastic and the driver's side ext. cab plastic area. I was going to make a wood 1" spacer to bring the mounting surface out, so I'd get more depth behind the speaker. I was going to cover the wood in matching tan carpet to finish it off. I know the 6x9's won't fit where the existing 4x6's are mounted, but by adding the spacer to the outside plastic (where the grille for the 4x6's is formed into the plastic) I was hoping to get enough room. Not sure if I explained it well enough to understand, I guess I'll just have to cut and make it work :loser: Chris
To get the interior trim off you will have to remove the rear seat. Also the wide piece that runs just under the back glass. The driver's side is 2 pieces You have to remove the front seatbelt and the ashtray from the armrest. There are 2 screw under the ashtray, then the armrest will come off. There are 2 screws behind it, plus more at the botom of the panel. After you remove all the screws, pull the panel out, it has several clips holding it on. Now you can remove the upper trim piece. Take the screw out of the cloths hanger tab, it is held on only by clips now. Pull the bottom out first.
For the passenger side, if I remember correctly there are only clips holding it in, but you will have to remove the bolt that holds the bottom of the rear seatbelt.
Having outlined all of that, I would urge you not to cut any of the rear plastic pieces or the metal of the cab in any way. Anything sticking out of those location s will be something for somebody sitting in the back to bang their head on real good. Plus later when you go to sell the truck the mods to the plastic or metal will drop your resell price considerably. The large plastic pieces in the back are quite expensive to replace also.
Also I never have really understood the appeal of 6x9s. A set of components up front and some upgraded speakers for the rear will blow them away in sound quality, probably in bass repro too.
Thanks, I'll try it when it warms up some so I don't break the plastic when it's cold. I've had the 6x9's for a couple years sitting in their boxes, never hooked them up to anything. The seat belt "buckles" stick out farther than the speakers would, plus I don't see how anyone could hit them unless they did it on purpose. But, you never know! :crackup: As far as resale value, this truck will always be mine. It's going to become strictly a farm truck. I just love the style of OBS trucks. Always have, always will. Thanks again, Chris
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
