have you considered it's an electrical problem, that you just temporarily fixed by moving the wiring and/or cleaning off the connector by disconnecting/connecting it?
The proper socket for them is e-torx
And yes, they go through to the underside of the body, so it's better if you clean off the parts sticking out as best you can prior to removing them, to reduce the chance of wrecking the nut welded to the cab, as it sucks to weld a new one to it.
Register a new accountSign in
