This is another of those 'coming from Ford' things... 😉
So... on my current rig (2018 F350 XL 6.2L 6spd) if I'm hauling something and don't want the truck to keep over shifting from 6th down to 4th on every little hill, I can use the +/- rocker switch on the shifter to 'lock out' 6th gear.  The driver's display console will then only show 5th on down, with whatever gear the transmission is currently in (5th, 4th, 3rd, etc.) highlighted.  This is separate from going to 'M'anual mode on the column shifter and then using the +/- rocker switch to manually *change* gears - although if I'm in 6th and lock that out, the tranny will bump down automagically.
From what I've heard/read, the GM/Chevy driver console only shows what gear/mode the column shifter is in i.e. PNRDL, unless you physically move it to 'L' which sounds like it's the analog to 'M'anual mode on the Ford.  Is that about right?
How then, do you know what gear you're in when the transmission is running in automatic?  Is there a function for 'locking out' say 10th or 9th gear, short of going to 'L' and having to run things manually?  Conversely, the manual shows that if one goes from 'D' to 'L' the transmission will automagically downshift from 10th down to 7th (or lower, depending on where it starts from).  Is it not possible to run in anything above 7th in manual or 'L' mode?
Edited by memilanuk
You can pull up the owners manual and read about it, but I’ll summarize  how the six speed works. I believe the ten speed functions similarly.
The “L” position is not a true manual mode (even though they call it that), but instead allows you to set the highest gear the transmission can shift into. The display shows “L5,” for example, if you are limiting it to fifth (locking out sixth).  The display will show L5 regardless of what gear the transmission is in.
If you shift into L while driving in 6th or 5th, the transmission goes to L4. If you are in 2nd, 3rd, or 4th when you select L, it will drop one gear (if in 4th it will go to L3, for example). You can then use the rocker switch to move the maximum gear up or down, except it won’t let you over rev the engine by selecting too low an L setting.
So... the 'L' mode on the GM/Allison works like the normal 'lock out' on a Ford?
I'd been skimming the manual, but I was looking more for info on what gear was displayed, etc.  I missed this:
Quote
This number is the highest gear that the transmission will allow while operating in L (Manual Mode). All gears below that number are available. As driving conditions change, the transmission can automatically shift to lower gears. For example, when L5 is selected, 1 (First) through 5 (Fifth) gears are automatically shifted by the transmission, but 6 (Sixth) cannot be used until the plus/ minus button on the shift lever is used to change to the range.
That there is *no* manual mode at all is a little off-putting.  I've been using that quite a bit lately hauling a heavy truck camper, to keep the 6spd / integrated trailer brake control from down shifting too far when I tap the brakes coming down a steep mountain pass.  Or to manually manage the gears going *up* a steep grade.  Then again, with a different transmission, maybe I won't need it as much?
How do you know what gear the transmission is actually in *prior* to going to 'L'?
Edited by memilanuk
There is no display that tells you what gear you are in. After two years driving the 6 speed I pretty much know what gear I’m in. I doubt I could develop such a sense with a 10 speed though. It shifts very smoothly though when you go to L and won’t let you overrev the engine.
1 hour ago, memilanuk said:
@Dustin Marshall you've had both the Ford 7.3L w/ the 10 spd and the GM 6.6L w/ their 10 spd... do you miss not having 'M'anual shifter control?
I don't see the point in a true manual mode. All you're missing (verses the lockout) is the ability to force an upshift and since these transmissions all already programmed to upshift whenever possible, I don't get why you'd want to lug an engine beyond what its tuned to upshift at.
We've been dealing with a 6 speed (Ford) that tends to over-shift (too far down) or gets to the point where it should upshift, but can't/won't, for whatever reason.  Sits there stuck at the RPM for shifting up, and after a bit, things start sounding... not good.  Options are either slow to a crawl in the middle of the road (interstate mountain pass) or manually kick it up a gear.  Yes, it slows down a bit then, but it doesn't sound like there's a second engine starting up under the hood either.
I use the GM lock-out all the time.  I just towed my camper cross-country with my 6.6L with Allison.  I kept it at 8th gear for pretty much the whole trip, unless I saw some grades coming up.  I'd manually downshift so the cruise didn't have to sense load and over-correct.  Works great.  I don't really care to know what gear I'm in.  I can tell from the tach what gear it is.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
