Have anybody brought these? Seen on Chevrolet websitNo image data founde, pricey for sure. $1,195.  But a very good way to keep  your stuff in the box of the truck.  Works with a cap or tonneau cover.
Edited by snowblind
spelling
Have anybody brought these? Seen on Chevrolet website. A bit pricey for sure $1,195.  But a very good way to keep  your stuff in the box of the truck.  Works with a cap or tonneau cover.
I screwed up the first post, but can't delete it.
I was looking at those Swing Cases, but they don't work with the Multi-Flex.  I opted to just get a couple of the collapsible crates from Costco, which are working out pretty well for now.
Duplicate post
Edited by GETGONE
You can use a passenger side swing case. You can use it on the driver side if you remove the flip up handle.
Interesting - I was just going to get the passenger side, to avoid the flip up handle issue, even though I have never used it.  But when you look at that site, and select only the passenger side, it still says w/o the Multi-Flex:
  • Will NOT Work w/ MultiPro/Multi-Flex Tailgate
I have to say, after my last purchase from Real Trucks, which was a frigging nightmare, the last thing I want to do is risk ordering something that doesn't explicitly say it's compatible on their side in the event there was an issue.
Edited by MrMagloo
I'm sure they never tested it. The bed is exactly the same on the regular vs Multi-Flex. The driver side handle is the only thing different which just unbolts. I read the instructions for installation and all you do is drill a couple holes for the brackets to mount in the bed. The tailgate has nothing to do with installation. The bigger issue is that it blocks the 110V outlet if you have that option. I don't but I did install a 7 way 5th wheel wiring plug in the plastic plug location so I have 12V in the bed to run a cooler, my air compressor, or whatever else I want.
Yeah, I've been trying to find the instructions for the SC-104P, but on every page across the internet, the linked instructions are for the SC-203P, for a FORD.  There it says there is no drilling.  I chatted with RT and they refuse to provide the correct instructions and claim there's no drilling. Typical BS with them. Lies to make the sale and out the door, then good luck if you run into issues.  Went round in circles for 2 months on a replacement for a Revolver.  On Amazon, sure seems like alot of folks complaining about broken hinges, etc.  Now that I know RT owns UC, umm, no thanks.
Driver side install, but proof showing you HAVE to drill to install them.
Found a passenger side video that shows my concern blocking the 110V plug or 7 way RV plug in my case.
Found proof they fit both sides of a Multi-Pro tailgate:
Edited by GETGONE
Hey GG - thanks for taking the effort to share those.  I'm definitely not drilling holes for a tool case that claims to handle 75 Lbs, and there are scores of reports of broken hinges.   If it was anyone other than RT making these things, I might risk it.
I've found knock off ones on ebay for cheap. They look exactly the same, but made in China of course. I don't know where the Undercover ones are made though.
    btm
    btm
  • Who's Online   4 Members, 1 Anonymous, 1,532 Guests (See full list)
