Hi, I have a 2020 3500 High country that hat a REV industries roll top tonneau cover. I am in desperate need of a tool box that will fit under and be accessible secured at the front of the ruck bed. Does anyone have any suggestions?
i have the same one gemarsh listed above, ill post some pics so you can see if itll suit your needs. i do not have a tounne cover on mine so no clue how much room you need, hope this helps. and also you will have to drill holes in the bed.20230828_042307.thumb.jpg.e43d59f42c601517c05cbb5a9b21a4e4.jpg20230828_042354.thumb.jpg.c632a0b8c0ae40b98356eef9e49612f4.jpg20230828_042409.thumb.jpg.03c9ba950f7e6ff45c00901bf6588d87.jpg
I have the Weather Guard aluminum chest box. I believe it is the 13.1cuft standard size. I love it!
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,358 Guests (See full list)
