11 hours ago, newdude said:
Not quite.  There is I think one or two extra crossmembers out back or larger ones.  The rails are the same though I believe.
@MTU Alum may be able to shed some details on this better?
The frames are the same structurally between 2500 and 3500.  The difference is on crew cab standard where they remove the overload springs fasteners from the frame on 2500s to save a few bucks.
#iworkforGM
Thank you all for the feedback. I'm really not trying to deceive anyone (or be ridiculed). The window sticker/build sheet clearly shows it's a 2500 with 3500HD frame and leaf springs. And it has the towing specs of a 3500... So I figured why not pop the 3500 badges on it.
My dealer couldn't even make sense of why GM does this. I bought what I bought and I love it either way.
Most dealers do not have a clue.
Reason#1 - advertising of high towing in very competitive 2500 market.  Ford has been doing this for years.
Reason#2 - some states there are vehicle registration or insurance reasons to be 2500 or 3500 where it's cheaper one way or other.
Reason#3 - for some models there are CDL advantages.  14,000 GVW trailers are popular.  If the 3500 model has 12100 GVW and 2500 NHT has 11750 GVW the 3500 would CDL whereas 2500 NHT does not with 14k GVW trailer.
#iworkforGM
#iworkforGM
That's excellent info! Thank you @MTU Alum
Not quite the same specs as the 3500. The payload is lower still.
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
