My 2014 5.3L Sierra recently started throwing a misfire code on cylinder 4. After changing spark plugs, wires, and coil packs, I've come to the realization that my lifter has more than likely failed. I knew it was burning oil previous to the failed lifter, so shame on me for not putting 2 and 2 together. The truck only has 140k on it, so I'm looking at doing the AFM/DOD delete rather than just fixing the failed lifter. Planning to keep the truck for many more years.
The mechanic sent me a link to the AMS racing kit which includes a Diablosport I3 Handheld; however, browsing this and other forums, there seems to be a number of recommended kits (e.g., Summit,Scoggin-Dickey) with a lot of preference for the one from Texas Speed. Hoping to hear some success stories. Which kit do you prefer OR would you steer away from kits entirely?
  • 2 months later...
I finished the DoD Delete this past weekend using  https://sdparts.com/i-24138746-l83-dod-afm-delete-kit-for-2014-2018-gen-v-5-3-engines.html. The kit had everything that you need to delete the AFM system. I used the Diablo i3 to turn off the DoD in the ECM.
I also replaced:
- Valve cover gaskets
- VLOM gasket
- Plugs
- Wires
- All Belts
I hope this helps.
I just used a SuperChips tune to disable DoD and my AutoSync device through BT Diesel does the same.
Nice thing about the SuperChips device is I could tune for 91+ octane and setup tire sizes for speedometer correction with larger tires.
The AutoSync does so much more than I could put in a single post for the BCM.
My Autel MaxiSys also does tire size correction but I didn't know that prior to getting the SuperChips device. I got it, the SuperChip device, mainly, for the tune.
Three years on, and DoD (AFM) disabled, no issues whatsoever.
Edited by MikeBMW
I just bought the Hypertech Spectrum. Its a canned tuned, with ability to shut off AFM, adjust speedometer for 22 inch tires, run tune with 91 octane, and adjust TQ management. I have mine on performance mode right now.  Eventually, I think I will get it professionally tuned along with the transmission.
    blueskytruc
    blueskytruc
  • Who's Online   1 Member, 0 Anonymous, 600 Guests (See full list)
