Anyone have a solution to remove the yellow cab light and replace with white or smoked?
Thanks!
  • 2 years later...
Just an FYI, I had GoRecon nstalled in May of 24 and this is what they look like now!
    Frank V
    Frank V
  • Who's Online   7 Members, 0 Anonymous, 1,225 Guests (See full list)
