The topic is oil
i have read the owners manual on what it says about 5 30 and 10 30 oil basicly it says 530 in the real cold winter weather and 1030 all other times (even thought the crank case cap says 530) i usually do this in my vehicles anyhow, but now im curious as to whether sythetic is worth the xtra coins,,,its 2.5 to 3 times the price of conventional oil which i have always used in my vehicles and got good results is it worth the extra $$$????? and what about semi syn its a wee bit cheaper. what brand oil and filter are u people using in your rigs? oh by the way im talking about a 2002 silv 4.8
I personally use non-synthetic in my truck and change it and the AC Delco filter every 3000 miles. Synthetic is not worth the money at all IMO if you change it every 3000 miles (unless its like -20 degrees). I feel like up to probably about 4000-4500 miles there is no benefit to synthetic (unless the temp requirement above). BUT although I dont use synthetic I am not one of those synthetic bashers who are totally against synthetic. I belive synthetic is well worth the money if you are going to do the extended drain deal which I think a few people do on here, and they can give you more information about what filters they use that last a large amount of miles, I am pretty sure Amsoil makes one because if you are using syn, the regular filter will need changed way before the syn oil.
there has been much debate about this on the board before. do a search and you will be able to spend hours reading about dino vs synthetic.
personally i use mobil 1 and an ac filter when the oil change message comes up on the dash. usually between 4500-5500 miles. It costs a little more, but i dont have to change it as often and from what i have read here and in other places it does the engine better.
Well, since the topic is oil, I've had over 22 years with finding the proper oil for my commercial trucks and my personal equipment.
First of all, you have to understand that the North American oil grading system is a complete joke. The API/SAE testing and "certification" is nonsense and is nothing more than "lowest common denominator."
Now before you become enraged, let's examine how oils are tested under the SAE J300 protocol:
Currently, the test is run for about 60 hours. The oil is allowed to thicken 275%, and 25% of the oil is allowed to boil off. You're allowed sludge deposits. The rings can stick but they can't break. The test engineer can add 6.5 liters of oil during the test to still earn a "passing grade."
Just based on the oil addition allowed, a car would leave a heavy blue cloud behind. An oil allowed to thicken 275% probably won't flow out when you remove the drain plug.
The scary thing is, the "new" J300 test is WAY better than the older J300 tests: oil was allowed to thicken 400%, almost 40% could boil off, etc.
The sad thing, several generations of drivers have been "educated" to believe that ALL oils are exactly the same. Why pay $4 a quart when a 69 cent a quart has the same exact "Starburst" certification?? We've also been led to believe that one viscosity grade is best for all seasons and all uses. Nonsense.
Oh, the test motors? A Buick 3.8 V6 and a special one cylinder engine, sort of like a Lawnboy motor.
In Europe, the ACEA has far stricter standards: oil is tested 200 hours, oil can only thicken 50%, only 15% can boil off, sludge of 7/10 max on "accelerated" aging, and the test engineer may NOT add make-up oil during the test.
Individual car makers have heavy input into these tests, and these same car makers are free to set their own standards as well. For example: Mercedes Benz 229.3, BMW Long Life 01, VW 506.01, etc.
In winter, due to my extreme cold temps, I run Mobil 1 0W-30. In summer I run Mobil 1 10W-30, but this summer I'm going to switch to the new Mobil 1 "SUV and Truck" 5W-40.
Based on my previous experience with my 1984 Ford and 1990 Toyota 4Runner, I did NOT lose MPG running a heavier oil (Delvac 1). Indeed, while living in Utah, I ran Mobil 1 15W-50 in my 4Runner with excellent results. Very quiet motor and no deposits even after +120,000 miles.
Since I like to keep my equipment forever, or at least past 150,000 miles, I don't think the extra "cost" of synthetics is a factor. However, my extreme cold climate in winter is a factor, so it's a "no choice" if you want long life. Perhaps in a mild climate you'd do well with a regular oil.
I don't follow the regular Qwikie Lube oil change of every 2,000 - 3,000 miles. I might change the filter every 3,000, but the oil stays in at least 10,000. No problems with Delvac 1 or with Mobil 1.
With my truck, I average about 1 quart every 4,200 miles running Mobil 1 0W-30, 1 quart every 6,800 miles running Mobil 1 10W-30. I'm looking forward to my Mobil 1 "Truck and SUV" 5W-40 experiment this summer, as "Truck and SUV" is basically a rebadged Delvac 1 commercial product.
In the end, if you feel it costs too much to run a good quality oil, feel free to use whatever makes you happy. In the end, you paid for the truck, it's your money, so do what you feel is best.
I've said it before: if I were leasing or trading every 2-4 years, I'd never open the hood.
Ever.
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
