I need to either get all new wheels or use a 1 inch spacer. I'm adding a level kit that requires this because of the new UCAs. Its a 2022 GMC 1500 4x4 crew cab with the GM 2inch factory lift that has the 20x9 275/60/20 OE set up. I want to stick to the 20x9 and same rubber size. For the level kit I need to get to 5.75 back spacing. Any thoughts on spacers? I've never used them.
Gonna have to be a call you need to make. Are they going to fit fine, probably? Are they potentially causing excessive wear to your bearings, also probably. I suggest you do your own research on the topic. Plenty of articles and resources regarding spacers and large offset wheels and their negative impacts on bearings. Personally I would rather run some wheel offset to push them out over spacers.
I did research this and that's why I was asking for opinions here. Since then, I've decided no spacers for the reasons you mention and others. I've got new wheels on the way.
I'm running 1.25" BORA spacers with factory wheels and 285/65R20 tires on my 2022.5 without any issues.
Running conservative width spacers doesn't cause any more wear than running more offset wheels, within reason. I've ran spacers and/or offset wheels for several hundreds of thousands of miles on several different trucks used for towing and hauling and have yet to have an issue with wheel bearings. If you go with some unreasonable spacer width and/or crazy offset, you're likely to have bad results.
Agree but I would say still need to keep in mind the warranty aspect IF you do have bearing failures. Dealer most likely won't approve work on bearings if they determine spacers or any wheel offset from stock is used. Would be a good idea to keep your stock wheels and tires around just in case a bearing starts going and throw them on before you go to dealer. Of course this depends on the dealer you go to. If you have no warranty then its a moot point.
    doylej24
    doylej24
  • Who's Online   5 Members, 0 Anonymous, 776 Guests (See full list)
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
