Does anyone know how to take the round connectors of off the two vacuum lines underneath the passenger side of a 2014silverado, mine is leaking air bad, but no check engine light, replaced map,MAF and evap still won't idle above 400rpm,I can see and hear the air leak but I can't see the connector,it Tee to the other 5/16 hoses and runs down the transmission to the ground
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
