Bought a 99 Silverado not long ago. Started with a ticking sound that sound almost like the turn signal sound. It does all the time . Only stops when I press on the brakes. It literally starts as soon as the battery is on with the engine off. What could it be?
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 263 Guests (See full list)
