Well here's my dilemma, I've got a 2007 Silverado 2500hd 4x4 with a 5 speed and a 6.0. It's a ext. cab long box and it's a got a 2 piece steel shaft. I know the 2015 2500hd trucks that are a double cab long box truck are 158" wheelbase, my truck is a 157.5" wheelbase. I'm just about positive that that shaft will work because I've heard of people doing it. My main concern is will I twist this driveshaft up because I like doing burnouts (dumping the clutch). Just not sure if it will hold up or not.
What's the dilemma?  You have a strong, working solution and you want to change it to something that might not be?
For my '04 Sierra extended cab, cab&chassis w 2-piece driveshaft, I believe the crossmember for the center support bearing would be in the way of a single-piece driveshaft, you might look at that, as  removing it would weaken the frame and modifying it to go around the driveshaft would require some fabrication work.
I want to get the one piece driveshaft mainly because i cant keep a support bearing in the truck it seems like they fail prematurely as well as i just started having a thud in the driveline after replacing my u joints and support bearing. I believe its coming from the support bearing rubber moving around and hitting on the cage of the bearing. With fabrication im not sure i know a guy that did this with his crew cab long box truck thats where i got the idea from.
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
