txchevy4ever Posted February 3, 2004 Posted February 3, 2004 I know I saw this posted here some time ago, and I have searched to no avail. My right side DRL finally burned out and I've got the replacement bulb, but I can't figure out how to physically replace the bulb. I know there has to be an easier way to do it other than to dissasemble the fan cowling and come at the headlight assembly from behind... it appears that the plastic covers on the headlights/DRL come off, but the two plastic tabs on the assembly don't appear to release. Any help you guys could provide would be appreciated. 2000 Tahoe 4x4 LT (New body style) Thanks!
Taaaaaaahoe? Posted February 3, 2004 Posted February 3, 2004 look in owners manual it shows you. But you will notice 2 pins that unlock, and pull up. the headlamp lense will mostly just fall out. Then the bottom lense will un snap with a tab you will see on the inside. Real easy 5 min job!! Mike
txchevy4ever Posted February 3, 2004 Author Posted February 3, 2004 Thanks for the help... believe it or not I had flipped through the manual, but not carefully enough... my brush guard added a couple of extra minutes but it was easy. Thanks again.
