I HAVE PUT THIS 2016 SILVERADO DRIVE TRAIN 5.3L MOTOR 8 SPEED AUTO TRANS AND AUTO 2 SPEED TRANSFER CASE IN MY 99 TAHOE WITH THE DASH AND STREEING WHEEL AND BCM FROM THE 2016 SILVERADO I HAVE REPLACE EVERYTHING ECM, HARNESS,PEDAL, THROTTLE BODY, AND I MACH THE ID NUMBER TO THE HARNESS WITH THE ECM, AND PEDAL, IN HPTUNERS WHEN I PUSH DOWN ON THE PEDAL IT SHOW IT MOVES FROM 0 TO 100 AND WHEN I USE HPTUNERS TO OPEN THE THROTTLE BODY IT MOVES IT FROM 0 TO 100 BUT THE PEDAL DOSE NOT MOVE THE THROTTLE BODY. DOSE ANYONE NO WHAT I NEED TO DO TO MAKE THIS WORK I THANK YOU FOR ANY HELP WITH THIS. FRM STANSON L MOORE
i give you credit a lot of people would not even try this. can you scan the ecm for codes. double check wiring and the plug going into the ecm. are you using the brake position sensor from the 2016
NOW IN HPTUNERS WHEN I PUSH DOWN ON THE PEDAL IT SHOW IT MOVES FROM 0 TO 88 AND WHEN I USE HPTUNERS TO OPEN THE THROTTLE BODY IT MOVES IT FROM 0 TO 86 BUT THE PEDAL MOVE THE THROTTLE BODY FROM 32 TO 46 . DOSE ANYONE NO WHAT I NEED TO DO TO MAKE THIS WORK I THANK YOU FOR ANY HELP WITH THIS. FRM STANSON L MOORE
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
