I’m trying to figure out the difference between Bilstein 5100s for my 2022 Silverado LTD Custom (My truck is a non-trailboss, normal ride height).
Does anyone know the difference between part # 24-309509 and 24-293297?
My goal is to get my truck to be at a trail boss ride height.
thanks in advance!
Edited by fondupot
thanks in advance!
It's compressed height.  The shocks are designed to be used on 0" lift to whatever height.
The 24-293297 is designed to work for stock height regular trucks but can be set to add lift.  Collapsed length is 16.28".  The 24-309509 collapsed length (17.58") is taller to get to the stock front height of a Trail Boss/AT4, and then obviously lift on a TB/AT4.
Edited by newdude
  • Thanks 2
Thanks @newdude
I ordered the 24-309509 the other day and just noticed this morning the other part number. So I should be ok installing these on the tallest setting to get my desired lift?
Update. This is what the folks at Shock Surplus just sent me.
24-293297 is for the base models.
24-309509 is for only the Trail Boss.
I guess I’ll return the ones I bought and get the correct part #.
6 hours ago, Hoopstar said:
I set them to the highest position to get 3.1" total lift in the front.
Yea, I don't want to extend them up that far. I am looking to be right at ~2" all around. Trucks sits pretty level front to back now, but its just too low for most of the job sites I go on.
Shock Surplus is doing me a solid and exchanging the shocks out free of charge.
  • 2 years later...
On 10/30/2023 at 9:27 AM, Hoopstar said:
I used the 509 part # on my non AT4 truck and they worked fine, get extra lift out of them.
I have a '25 RST Duramax and could get my hands on a set of very cheap, almost new x509 (intended for the trail boss)
Looking for a 1.5" lift/level in the front - if I get these and install at the lowest setting (i.e. no lift), would I end up with 1.5 or 2" of lift?
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 490 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
