2017 Denali 3500HD.
Coming home from recent trip, noticed automatic headlights won't turn off in the daylight, dash stays dim and symbol next to speedo is present. I can manually turn them off but dash stays dim telling me the system thinks its still dark. I am using BT Diesels auto sync to reconfigure headlights to USA spec. The auto sync programming was removed and the unit unplugged and the headlights still won't turn off in the daylight. With key on engine off the headlights on this rig could be turned off even though it was Canada spec and the dash would always respond to night and day changes even though the headlights were always on.
I have reached out to BT Diesel hoping he might have a solution or at least a place to start diagnosing. He is extremely busy and I hope to hear something from him later in the week, in the meantime was hoping maybe someone here has stumbled across this.
Thanks in advance!
If BT Diesel and the Autosync dongle for the OBD are connected (technically, The OBD dongle doesn't need to be connected but does for an update), log on to your computer and change the settings for the auto lights on as far as light input into the sensor on the dash. Then, (plug in the OBS dongle) go into your Autosync settings in your truck  and update the tune.
I have mine set to a sensitive setting in case of clouds and potential rain.
I'm sure your truck has the light sensor on the dash?
After any changes, your Autosync can be disconnected unless you want to use some of the features in the OSB dongle unrelated to your truck settings.
Also, always make sure you're receiving the latest updates through the Autosync settings on your trucks infotainment system.
Edited by MikeBMW
What setting did you change? This issue is only within the last few days and no settings have been changed within that timeframe.
Here's a screen shot of the hierarchy to the setting:
Edited by MikeBMW
    d.lowrey
    d.lowrey
  • Who's Online   2 Members, 0 Anonymous, 3,577 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
