I have a 2015 Silverado LTZ currently on stock suspension. I bought 20x12 wheels with -44mm offset and 275/65r20 tires. I bought a 2” rough country level kit to install to fit the tires but am worried it’ll still rub without trimming the bumper. Will it fit?
I am not sure if it will fit, I guess you will just have to try it since you already have the wheels and tires to see. But I saw you bought the Rough Country level. I had those and they did do what I needed. But... When it came time to change out the front struts, it turned into a nightmare to remove the RC Spacers. If you have no intentions of ever having to change the front struts, you will be ok. But when time comes to change them, the hardware that comes with the kit will rust out and become a challenge to remove. Here was a thread detailing what I went through.
Just wanted you to be aware of what will probably happen. There are other better leveling options however they are a bit more expensive.
    JD1964
    JD1964
  • Who's Online   4 Members, 0 Anonymous, 495 Guests (See full list)
