2018 GMC Sierra 1500 5.3L I have been having issues with my truck losing power randomly. All my grounds have been cleaned and seem fine. Now one of the hot connections on my battery fuse block is overheating and melting the plastic cap. I can replace the cable and fuse block but I'm not convinced that will solve the problem. Has anyone else had this issue?
