6 speed or 8 speed?
If 6 speed, Transmission has left the chat.
The fluid pump is probably smoked, probably from the converter failing.
14 hours ago, Davin Joiner said:
8 speed.
Could be a bad valve body or fluid pump.  Either way, time for a trip to the dealer or a transmission shop.
    • *Your
